Discussion topic: Wi-Fi keeps dropping since I changed provider
Message posted on 12 Sep 2025 09:19 AM
I have been with Sky for 12 years and with broadband through sky or NowTV never had any issues with Internet connection on the TV. Since I've changed provider it keep dropping 5-8 times A DAY!! Its so frustrating.
Message posted on 12 Sep 2025 09:19 AM - last edited: 12 Sep 2025 09:20 AM
Re: Wi-Fi keeps dropping since I changed provider
Try powerline adapters
some say turning off band steering on the router can help.
Message posted on 12 Sep 2025 09:22 AM
I cant find that on my router
Message posted on 12 Sep 2025 09:26 AM
Which router is it? They don't all allow that level of control.
Message posted on 12 Sep 2025 09:27 AM
@RoseT12 wrote:I have been with Sky for 12 years and with broadband through sky or NowTV never had any issues with Internet connection on the TV. Since I've changed provider it keep dropping 5-8 times A DAY!! Its so frustrating.
Which provider did you change to? What kind of router did they provide you with?
Message posted on 19 Sep 2025 08:01 AM
Ok, it's taken me a while but I have fixed this problem.
Sky Q only uses the 2.4 ghz band on your router.
Now.if you have the same SSID for both the 2.4 and 5 ghz channels the sky box gets confused (ie the Q box is a piece of **bleep**).
The fix that I found
On your router open up a guest 2.4 wifi, I called mine sky_box , create a connection password.
Connect to this wifi on your sky box and once connected just hide the SSID on the router.
So far i have no drops, previously I had 4 to 6 a day.
Cheers
Campo
Message posted on 19 Sep 2025 10:49 PM
@Campo2 wrote:Ok, it's taken me a while but I have fixed this problem.
Cheers
Campo
Very interesting!
Message posted on 20 Sep 2025 09:31 AM
I should say this was because I switched from SKY Broadband to EE
I am also using a TPLink router as EE's was very poor ( max 16ft coverage)
Message posted on 20 Sep 2025 10:50 AM
Yeah EE's router probably wouldn't have allowed that level of customisation either
Message posted on 20 Sep 2025 12:00 PM
EE's router was a nightmare, I bought a TPlink extender to create a mesh as the router was so poor, turns out that the EE router purposely blocked the Tplink channels, fortunately I still had a wifi 6 Tplink router to hand, I can now get wifi 80ft down my garden.
