26 Jul 2023 06:45 PM
Make sure you..
•have the latest version of the Sky Go app
•have the option in Sky Go settings “connect to sky Q box” checked
•are on the same Wi-fi network as the Q box is on?
27 Jul 2023 07:17 AM
Yep - all of those.
27 Jul 2023 10:09 AM
this is great if you have iphone but not for Android users do we know when this feature will drop onto android as it dose seem like a really good function
27 Jul 2023 12:45 PM - last edited: 27 Jul 2023 12:47 PM
@tiashannon sorry can’t help you then if your on the latest iOS, app version and on the same network and told it to look for the Q box it should be there.
@Phillip87 Well Sky have confirmed it’s coming to Android not much you can do other than wait or use one of the third party apps as I had been doing for years since moving from + to Q
04 Dec 2023 05:38 PM
Is there any update on this? Would be great to have a 'virtual remote' on my android phone for those times when you're really comfy on the sofa with all your drinks and snacks within reach but that little Q remote is just out of reach! 😆
04 Dec 2023 05:48 PM
Unfortunately it seems to have been pushed back to 2024 for Android @Forever+Customer with no specific date set
04 Dec 2023 05:54 PM
Such a shame, I'm making the most of it on iOS, the one thing I would change is how to swap between boxes when in remote mode a drop down at the top would be ideal. But tbh I'm just happy that things have progressed and I don't have to use third party remotes.
07 Jan 2024 08:48 PM
I have 2 sky q mini boxes but they don't show up under devices on my sky go app virtual remote
07 Jan 2024 08:59 PM
The don't show up in the choose your box section when you press the remote icon then settings (or setting remote then settings again if you don't use the icon) ?
08 Jan 2024 07:36 AM
No when I do settings the only box it gives me as an option is the main sky box which is in a different room . The sky q mini box is in the room I'm in but does not come up as an option
08 Feb 2024 11:48 AM
So a billion pound company can't afford to get 1 developer in to make an app that is slready there. Unbelievable.
