Discussion topic: Upgrade to 4k
This message was authored by: edgie700
Upgrade to 4k
Hi all , I currently have standard HD on my sky Q , I'm thinking of upgrading to 4k , does anyone know how much it is to add 4k to a full package , thanks
Re: Upgrade to 4k
Assuming you have a UHD-capable box then it retails at £4pm (on top of HD pack).
Check hardware version here: https://www.sky.com/help/articles/sky-software-updates
Avatar for edgie700
Level 4 icon
Re: Upgrade to 4k
I have a hd only box
Re: Upgrade to 4k
hi @edgie700
You can upgrade by calling SKY but, unfortunately, they usually charge around £99 I think
BTW if you do upgrade remember to take out your viewing card before giving your old box over.
Re: Upgrade to 4k
One of the original 1TB boxes?
Avatar for edgie700
Level 4 icon
Re: Upgrade to 4k
Yes a sky q 1tb box
