4
This discussion topic has been answered Discussion topic: Unable to add Netflix to package
This message was authored by: polar68
I have Sky Q with Signature and Ultra HD and am looking to add the Ultimate TV package to watch Netflix. The option to add this in my account on the website is greyed out (it's actually white but nothing happens when I tap it, like its deactivated) - anyone know why? Also, as I have already UHD add-on with multi screen, does that mean I get the premium Netflix package for the £6?  Everything is very confusing.  Thank you
Avatar for polar68
Level 2 icon
This message was authored by: polar68 Answer
Re: Unable to add Netflix to package
Thank you for your reply.  I have managed to add Netflix directly via my Sky q box.
hi @polar68
I suspect the reason for the option being greyed out for you is that I don't think your base package is SKY Signature that is needed (your mention of UHD via Multscreen experience suggests this)
There is a good chance that switching to SKY Signature will be cheaper for you, but it all depends on your add ons - I saved when I switched a few years ago
Once you switch your UHD  would be vi the UHD specific add on  that (in addition to HD) which opens up the Netflix higher tier
Is there something specific you feel is stopping you switching to Signature
Avatar for polar68
Level 2 icon
Hi, I already have Sky signature.  I have everything but Netflix
Apologies - I misunderstood your reference to UHD with Multiscreen.
Multiscreen used to open up  UHD on the older base packages.
In which case I am not sure why the option is greyed out - you may need to call
As you have Signature with UHD (& I assume HD) then yes you do get the Premium tier of Netflix ( 4 concurrent  screens & UHD/HDR)  once you manage to add the Netflix (Ultimate add on)
Avatar for polar68
Level 2 icon
Answered - Go to Answer
