18
This discussion topic has been answered Discussion topic: UHD on BBC iPlayer not working on SKY Q Box.
This message was authored by: Graeme100
UHD / 4K not available on my SKY Q Box.....I am sure it was available before??
This message was authored by: nigea99 Answer
Re: UHD on BBC iPlayer not working on SKY Q Box.
@Graeme100 wrote:
Chodley
Thank you for your interest!
Its a Panasonic 4K 72" TV  Model 4KTV-JUP
I can't find any info about 8 or 10 bit selection on the TV
When I set up my  SKY Box it only works in 8 bit with this TV
I can watch BBC IPlayer in UHD on the app on the TV but not on the app on my SKY Q Box
If your panasonic is anything like mine try setting the HDMI  Auto Setting (might be called something slightly different) to Mode 2 &  then try setting 10 bit on the SKY box again
As @Chodley says you need 10 bit for HDR (but not for  UHD in SDR) - this is probaly why you can't get UHD on iPlayer on SKY Q
BTW We generally suggest using the TVs inbuilt apps anyway
hi @Graeme100
Which box do you have ?
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box  - iPlayer not available in UHD
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply) - iPlayer not available in UHD
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box - iPlayer available in UHD
Hi @Graeme100   What is the hardware version? Home -> Settings -> System info -> Hardware version. Is iPlayer Beta ON? In iPlayer, Settings -> iPlayer Beta -> ON
BETA hasn't needed to be on since 2020 to access UHD, it's available by default.
Only the third generation of Sky Q boxes support iPlayer in UHD.
Avatar for Graeme100
Level 2 icon
Thank you for your quick reply
SKY Q Box Hardware Version is....32B206 and Software Version is ...Q300.000.06.00L(5yzv4ns)
BBC iPlayer is on Beta Mode and Version is 35.33.0.0
I can get UHD on the  iPlayer App on my TV but not on the App on my SKY Q Box
@Graeme100 have you checked that your boxes resolution settings are still set to 2160 and 10 bit
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Level 2 icon
Box is set on  2160 and 8 Bit.  Settings should fine as I am just watching Formula 1 in UHD!
@Graeme100
In which case probably worth doing a power down restart
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Why 8bit and not 10bit? F1 is in HDR and you're missing a lot in SDR imho.
Level 2 icon
My TV only supports 8 bit but that is still in HDR but just not as good as 10.bit
Not sure how that can work. HDR signals are always 10 bit (or more). You need the extra data to represent the wider range of colours/brightness. I'm very curious. May I ask which model TV it is?
Level 2 icon
Chodley
Level 2 icon
Chodley
It may be I am getting mixed up with.  . 4K.    UHD.   HDR. ?
@Graeme100 wrote:
Chodley
Level 2 icon
Thanks I shall check the settings shortly.
