18
This discussion topic has been answered Discussion topic: UHD on BBC iPlayer not working on SKY Q Box.
Avatar for Graeme100
Level 2 icon
This message was authored by: Graeme100
Re: UHD on BBC iPlayer not working on SKY Q Box.
I found the HDMI Settings as suggested but I don't have the option to change it from 1
The choice of settings is "greyed out" so not able to change selection.
 I shall have to look further and see what I can find about this.
Thanks for helpful replies.
Might be locked by the current picture mode?
Level 2 icon
       UPDATE
Problem now resolved.
Found the HDMI Option on myTV and how to reset it for SKY Box input
Set to option 2  and SKY Box now able to set to 10 bit.
I now have HDR on the BBC iPlayer app.
Thanks all for your interest and advice
@Graeme100 wrote:
       UPDATE
Glad you have managed to get it sorted.
If you have the SKY UHD add on then you will, also,  notice the difference with the UHD cntent that is in HDR
Answered - Go to Answer
