This discussion topic has been answered Discussion topic: UHD on BBC iPlayer not working on SKY Q Box.
Message posted on 18 Apr 2025 02:21 PM
UHD / 4K not available on my SKY Q Box.....I am sure it was available before??
Message posted on 19 Apr 2025 02:08 PM
@Graeme100 wrote:
Chodley
Thank you for your interest!
Its a Panasonic 4K 72" TV Model 4KTV-JUP
I can't find any info about 8 or 10 bit selection on the TV
When I set up my SKY Box it only works in 8 bit with this TV
I can watch BBC IPlayer in UHD on the app on the TV but not on the app on my SKY Q Box
If your panasonic is anything like mine try setting the HDMI Auto Setting (might be called something slightly different) to Mode 2 & then try setting 10 bit on the SKY box again
As @Chodley says you need 10 bit for HDR (but not for UHD in SDR) - this is probaly why you can't get UHD on iPlayer on SKY Q
BTW We generally suggest using the TVs inbuilt apps anyway
Message posted on 18 Apr 2025 02:51 PM
Re: UHD on BBC iPlayer not working on SKY Q Box.
hi @Graeme100
Which box do you have ?
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box - iPlayer not available in UHD
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply) - iPlayer not available in UHD
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box - iPlayer available in UHD
Message posted on 18 Apr 2025 02:52 PM
Hi @Graeme100 What is the hardware version? Home -> Settings -> System info -> Hardware version. Is iPlayer Beta ON? In iPlayer, Settings -> iPlayer Beta -> ON
Message posted on 18 Apr 2025 04:35 PM - last edited: 18 Apr 2025 04:38 PM
BETA hasn't needed to be on since 2020 to access UHD, it's available by default.
Only the third generation of Sky Q boxes support iPlayer in UHD.
Message posted on 18 Apr 2025 04:36 PM
Thank you for your quick reply
SKY Q Box Hardware Version is....32B206 and Software Version is ...Q300.000.06.00L(5yzv4ns)
BBC iPlayer is on Beta Mode and Version is 35.33.0.0
I can get UHD on the iPlayer App on my TV but not on the App on my SKY Q Box
Message posted on 18 Apr 2025 04:47 PM
@Graeme100 have you checked that your boxes resolution settings are still set to 2160 and 10 bit
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 18 Apr 2025 05:03 PM
Box is set on 2160 and 8 Bit. Settings should fine as I am just watching Formula 1 in UHD!
Message posted on 18 Apr 2025 05:13 PM
In which case probably worth doing a power down restart
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Message posted on 18 Apr 2025 05:39 PM
Why 8bit and not 10bit? F1 is in HDR and you're missing a lot in SDR imho.
Message posted on 18 Apr 2025 08:27 PM
My TV only supports 8 bit but that is still in HDR but just not as good as 10.bit
Message posted on 19 Apr 2025 07:27 AM - last edited: 19 Apr 2025 07:30 AM
Not sure how that can work. HDR signals are always 10 bit (or more). You need the extra data to represent the wider range of colours/brightness. I'm very curious. May I ask which model TV it is?
Message posted on 19 Apr 2025 01:54 PM
Chodley
Message posted on 19 Apr 2025 02:03 PM
Chodley
It may be I am getting mixed up with. . 4K. UHD. HDR. ?
@Graeme100 wrote:
Chodley
Message posted on 19 Apr 2025 04:49 PM
Thanks I shall check the settings shortly.
