Discussion topic: Thumbnails not displaying
Message posted on 15 Jul 2023 11:40 AM
Hi
My sky q box works fine - except it does not display any thumbnails for recordings, on demand, catch up etc. Apps strangley displays the thumbnail for Netflix but nothing else.
Any ideas?
For info I have my Sky Q box with a wired connection to an eero router, which is wired to the sky modem. I have gigabit broadband from sky.
Message posted on 15 Jul 2023 01:26 PM
Re: Thumbnails not displaying
@Bertmus wrote:Hi
Any ideas?
Those are symptoms of not having an internet connection to the Sky Q box.
Message posted on 15 Jul 2023 02:51 PM
Thanks @Invisiblename
I dont think thats the problem. As the settings screen shows an internet connection, and I can still stream Netflix. Netflix help also shows a connection to each of its servers.
Message posted on 15 Jul 2023 04:14 PM
@Bertmus wrote:
Hi
Any ideas?
@Bertmus Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 15 Jul 2023 10:34 PM
@Laing1 Thanks. Yes I have tried this several times. Sometime a couple of the thumbnails reappear for a short while, but never a 'full recovery'
Message posted on 04 Mar 2025 09:14 PM
Mine has started doing the same thing and rebooting the Q box only works once, I'm fed up with having to repeat the process. This evening rebooting twice hasn't fixed it. I guess the box is knackered but how to convince the sky service without getting sent round the doom loop of rebooting. Any ideas anyone?
Message posted on 04 Mar 2025 09:29 PM
Hi @Geoff2ey Rebooting your broadband router is also required to refresh its DNS.
Message posted on 04 Mar 2025 10:30 PM
Many thanks for that, it didn't seem logical 'cos the streaming apps still played, but it has worked, by rebooting both the Q box and my home router.
One knock-on effect is that a second tv (upstairs on a mini box ) then needed its mini box rebooting before I could watch tv, even though it was working fine yesterday. Fingers crossed when I go back downstairs tomorrow that the main Q box remembers to behave!
thanks again
