3
This discussion topic has been answered Discussion topic: UHD
This message was authored by: Fidel+59
UHD
Help! Unable to watch in UHD. Nothing has changed my end. Get this my message.
 Sky Q. Sony A95L
N Jenkins
Avatar for Fidel+59
Level 4 icon
This message was authored by: Fidel+59 Answer
Re: UHD
Sorted now thanks. I turned everything off at mains and restarted as advised. There must have been some kind of update somewhere as I never changed anything.  Anyway thanks for your support 🙏
N Jenkins
Re: UHD
Hi @Fidel+59   Have you tried a new high speed HDMI cable? Is the HDMI seated fully in the sockets? Has the channel that Sky Q is connected to set to Enhanced? Have you power rebooted everything, TV and Sky Q box?
Avatar for Fidel+59
Level 4 icon
Re: UHD
I believe so. I'm out at the mo but will go through the list thanks.
N Jenkins
Avatar for Fidel+59
Level 4 icon
Re: UHD
N Jenkins
