Discussion topic: Mini box will not let me set up recordings on it.
Message posted on 04 Mar 2025 09:45 PM
My mini box has just been replaced but I can't set up recordings on it. What is wrong as I haven't had this problem before?
Message posted on 04 Mar 2025 09:59 PM
Re: Mini box will not let me set up recordings on it.
Hi @Tdm.I
Assume you are not trying to set up UHD recordings.
Reboot the mini as above.
