Discussion topic: Technical problem
This message was authored by Rafair7643 This message was authored by: Rafair7643
Technical problem
Hello,
Having problems with signal on most of our channels.  Message on screen says, "Technical problem with signal"
Only channels 110 (Gold) 111 (Dave) and 150 (5Live) seem unaffected.  Sometimes error message disappears and signal is patchy.
Signal check on box states  - Strength 60, Quality 90.
Anyone got any ideas?  Thanks
This message was authored by Laing1 This message was authored by: Laing1
Re: Technical problem
@Rafair7643 wrote:
Hello,
@Rafair7643 Have you tried rebooting your main Q box ? ie
Rafair7643
Hi there,
Yes have done this a couple of times without success.
Thanks for the reply.
@Rafair7643 wrote:
Hello,
Could indicate a slight misalignment of your Satellite dish @Rafair7643
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Rafair7643
Thanks for the advice.
Followed the steps without too much success.  Got some channels back, however, Sky Sports and Cinema still unavailable.
Have booked an engineer visit.
