Discussion topic: My sound cuts out for a second every 20 seconds or so - what is the setting change require please ?
Message posted on 06 Dec 2023 02:26 PM
My sound cuts out for a second every 20 seconds or so on my main SkyQ box - what is the setting change required please (Sky have walked me through this before)
Message posted on 07 Dec 2023 09:20 AM
Re: My sound cuts out for a second every 20 seconds or so - what is the setting change require pl...
Hi there @Gunny24 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 09 Dec 2023 09:51 AM
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Message posted on 25 Dec 2023 06:06 PM
Re: My sound cuts out for a second every 20 seconds or so - what is the setting change require pleas
Did you get this resolved? I have the same problem.
Message posted on 25 Dec 2023 06:24 PM
This has also been happening for me over the last week or so.
It's so annoying.
I remember a similar problem years ago which I think had a very long thread on here.
Not changed any settings, although TV has had a software update, but only occurs with Sky Q (not TV apps).
Have tried a Q box reset (from the engineer menu) as suggested on another thread, with no change.
HDMI to TV (Sony A80J) then ARC to amp (Sony 1040).
Message posted on 25 Dec 2023 08:01 PM
I've tried a reset ages ago when it first started. I was told its to do with Ethernet connection on the main Sky Q box. Mine only occurs on the main box and not on my 2 Sky Q mini boxes. All are connected via Ethernet. Apparently the issue has been around for years.
Message posted on 27 Dec 2023 08:14 AM
Hello, there is several recent posts on this forum regarding sound drop outs.
this was a big problem before and you did finally fix it but could it if come back in the recent software update?
please investigate thank you
software version Q230.000.14.00L (5nf3ptk)
hardware version 32B12D
Also is there a way we can link the sound drop threads together?
Message posted on 28 Dec 2023 09:25 AM
I've just checked mine and I have the hardware and software version you listed and still have the sound drop outs. :-(. Any other ideas?
Message posted on 28 Dec 2023 09:30 AM
I have a Sky Engineer coming next week (for a broadband issue) and have been asked to show him the sound drop out issue on the SkyQ Main Box (mini box is fine). I've jus tcompleted a software update on the SkyQ Main box as the TV Guide wasnt displaying and I'm sure the sound drop-out restarted then.
Message posted on 28 Dec 2023 09:36 AM
So we both have the same software version and are experiencing the same problem as others on this forum.
I believe since the last update to
this has caused the sound drop outs and we need someone from sky to intervene and start running some tests.
this was a major issue before with a previous software update and took sky some time to fix.
Message posted on 28 Dec 2023 09:38 AM
@Mr+Flibbles+86 @Please could you investigate sound drop issue.
several recent posts on this forum all complaining of the same, I believe it's since recent software update
many thanks
Message posted on 28 Dec 2023 10:09 AM
Just to confirm I'm also on the same software version and hardware.
Message posted on 20 Jan 2024 05:11 PM
I've one of the other threads open. Not had any contact to it, from Sky.
I'm on the same software version 5nf3ptk but a different hardware version (3rd box trying to fix the problem, so think I have newer hardware version) 32C008.
Message posted on 21 Jan 2024 07:49 AM
Hi. Did the engineer come and wre they able to help with your drop outs?
Message posted on 21 Jan 2024 09:42 AM
Had 2 engineers out. They just swapped the box and kicked off a software update...
The second one said it must be the TV, ignoring that I was telling him I'd tried another TV with the same results.
We more or less watch streaming on the TV now and only use Sky when we really need to.
