Discussion topic: My sky mini box is not working
Message posted on 27 May 2024 09:49 AM
I have tried all connections and pressed reset but I am not getting a signal on my tv and the little light is remaining red
Message posted on 27 May 2024 10:13 AM
Re: My sky mini box is not working
Hi @JonMoxon
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
