39
This discussion topic has been answered Discussion topic: Technical fault
Re: Technical fault
@Debsholden1
If a reboot hasn't worked for you you'll have to call Sky to arrange an engineer. You can't arrange one via the forum.
This message was authored by: austinburns
Re: Technical fault
I have rebooted the sky box and reset broadband still says technical fault on q box
what nexr
This message was authored by: Pressure
Re: Technical fault
How do you reboot box?
Re: Technical fault
@Pressure
~ press the 🏠 button
Re: Technical fault
Hi I have tried all the options
i have had 2 q boxes for more than 7 years and now has to replace
prompt service .Exceeded number of q boxes is a nuisance when connecting replacement
. this should be quicker and easier
This message was authored by: glynis68
Re: Technical fault
technical fault on all channels
Re: Technical fault
@glynis68 have you followed the information in the link below
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/an-on-screen-message-sky-q/articles/there...
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Julie131
Re: Technical fault
My sky is showing  technical fault on recordings and catch up
Re: Technical fault
Have you looked at the link posted above?
This message was authored by: Olivertwist1
Re: Technical fault
I have had sky streaming for less than a month and noticed it goes to breaking up during adverts I have switched off a wall and rebooted it but it still keeps happening
Re: Technical fault
This is the Q forum. There is a separate forum for Stream.
And this thread is about a specific error message that appears on-screen, not general picture breakup. You'll probably find some help on that in theStream section .
This message was authored by: Dawn541
Re: Technical fault
Yes done that
Re: Technical fault
This message was authored by: cuke
Re: Technical fault
@Dawn541 wrote:
Done what? You would be better off starting a new thread then piggybacking onto another...
This message was authored by: Vintyjan
Re: Technical fault
Already re booted
Answered - Go to Answer
