This discussion topic has been answered Discussion topic: Technical fault
Message posted on 11 Nov 2023 03:10 PM
Re: Technical fault
If a reboot hasn't worked for you you'll have to call Sky to arrange an engineer. You can't arrange one via the forum.
Message posted on 15 Nov 2023 07:07 AM
Re: Technical fault
I have rebooted the sky box and reset broadband still says technical fault on q box
what nexr
Message posted on 08 Dec 2023 07:39 PM
Re: Technical fault
How do you reboot box?
Message posted on 08 Dec 2023 07:41 PM
Re: Technical fault
@Pressure
~ press the 🏠 button
Message posted on 09 Dec 2023 08:06 AM
Re: Technical fault
Hi I have tried all the options
i have had 2 q boxes for more than 7 years and now has to replace
prompt service .Exceeded number of q boxes is a nuisance when connecting replacement
. this should be quicker and easier
Message posted on 10 Jan 2024 07:18 PM
Re: Technical fault
technical fault on all channels
Message posted on 10 Jan 2024 08:12 PM - last edited: 10 Jan 2024 08:18 PM
Re: Technical fault
@glynis68 have you followed the information in the link below
Message posted on 18 Jan 2024 09:55 AM
Re: Technical fault
My sky is showing technical fault on recordings and catch up
Message posted on 18 Jan 2024 10:31 AM
Re: Technical fault
@Julie131 wrote:My sky is showing technical fault on recordings and catch up
Have you looked at the link posted above?
Message posted on 05 May 2024 09:33 AM
Re: Technical fault
I have had sky streaming for less than a month and noticed it goes to breaking up during adverts I have switched off a wall and rebooted it but it still keeps happening
Message posted on 06 May 2024 11:48 AM - last edited: 06 May 2024 11:54 AM
Re: Technical fault
@Olivertwist1 wrote:I have had sky streaming for less than a month and noticed it goes to breaking up during adverts I have switched off a wall and rebooted it but it still keeps happening
This is the Q forum. There is a separate forum for Stream.
And this thread is about a specific error message that appears on-screen, not general picture breakup. You'll probably find some help on that in theStream section .
Message posted on 15 May 2024 10:09 AM
Re: Technical fault
Yes done that
Message posted on 15 May 2024 10:11 AM
Re: Technical fault
Message posted on 15 May 2024 10:13 AM
Re: Technical fault
@Dawn541 wrote:
Done what? You would be better off starting a new thread then piggybacking onto another...
Message posted on 23 May 2024 09:05 PM
Re: Technical fault
Already re booted
