39
This discussion topic has been answered Discussion topic: Technical fault
This message was authored by: JohnW16
Technical fault
All channels showing;
There is a technical fault with this channel. Please try again later
Re: Technical fault
@JohnW16
What have you tried already? Rebooting the main Sky Q box is the normal first step.
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Technical fault
@JohnW16
Avatar for JohnW16
Re: Technical fault
Thanks, is that just switch power of to reboot sky box?
Re: Technical fault
Yes, leave off power for a few minutes , before restarting.
Also, if it persists, have a look at this help article;
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/an-on-screen-message-sky-q/articles/there...
Re: Technical fault
@JohnW16
Use remote - place main box in standby
Switch off at plug for at least 30 seconds
Switch back on at plug
Follow on screen prompts
When screen goes black and blue circle on box stops pulsating wait another 30 seconds
Press the 🏠 button on your remote
Avatar for JohnW16
Re: Technical fault
 @Daniel0210 @lettice Sky back on again, thanks for your help
This message was authored by: Lilly09
Re: Technical fault
My box is saying technical fault please insert viewing card but my viewing card is already in
Re: Technical fault
@Lilly09 Have you tried rebooting your main Q box ie
if that doesn't work
You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: davus4
Re: Technical fault
Technical fault. Please try again later. Showing with all channels. Have had to do this several times in the space of a few weeks. Not looking for patronising advice about switching off and then switching on again, need a more long term solution
Re: Technical fault
Sincere apologies for tone, was just cut off after waiting 45 minutes to get through to advisor which is why I'm a bit peeved. No excuse taking my frustration out here so apologies.
This message was authored by: MARK100s
Re: Technical fault
Each channel is saying technical fault
This message was authored by: Levanter01375
Re: Technical fault
I have a message in tv saying there is a technical issue and sky are working hard to resolve it
Re: Technical fault
The screen is blank apart from that message
This message was authored by: Debsholden1
Re: Technical fault
No still not working
Re: Technical fault
Engineer wanted constant problems with this stupid a box
Answered - Go to Answer
