Discussion topic: TV Guide does not load
Message posted on 06 Mar 2023 04:45 PM
The TV guide is constantly loading, with the message: "Waiting for TV Schedule..." remaining on screen. We've left it for hours and it still will not load.
We don't have Sky Q but did not have the option for Sky TV in the categories.
Message posted on 06 Mar 2023 04:46 PM
Re: TV Guide does not load
If you don't have Sky Q what do you have Sky+, Sky Glass, Stream?
@AGodfrey123 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 06 Mar 2023 04:47 PM
Do you have Sky+ then @AGodfrey123
Sorry it is Sky Q actually
Message posted on 06 Mar 2023 04:48 PM
Yes done this, still encountering the same issue
Try rebooting as suggested by @Laing1 then.
Hi @AGodfrey123
Message posted on 06 Mar 2023 04:55 PM
Thanks, I've rebooted but now I have no satellite signal. Any instructions on how to fix this?
Message posted on 06 Mar 2023 05:04 PM
Did you reboot or carry out the Reset Settings @AGodfrey123?
Message posted on 06 Mar 2023 05:05 PM
@AGodfrey123 Do you have your own satellite dish or are you being served by a communal Integrated Reception System installation?
Message posted on 06 Mar 2023 05:09 PM
I did the Reset Settings
Communal dish
Message posted on 06 Mar 2023 05:15 PM - last edited: 06 Mar 2023 05:20 PM
@AGodfrey123 Can you confirm that your LNB type is set to SCR
If it was showing Wideband, change the LNB type to SCR and then remove the mains power from your Sky Q receiver for 20 seconds and then restore mains power to your Sky Q receiver.
Message posted on 06 Mar 2023 05:15 PM - last edited: 06 Mar 2023 05:16 PM
@AGodfrey123 wrote:
Communal dish
Then you need change the LNB back to SCR @AGodfrey123
After doing this you need to power cycle the Q box
