Discussion topic: TV Guide does not load
This message was authored by: AGodfrey123
The TV guide is constantly loading, with the message: "Waiting for TV Schedule..." remaining on screen. We've left it for hours and it still will not load.
We don't have Sky Q but did not have the option for Sky TV in the categories.
Re: TV Guide does not load
@AGodfrey123
If you don't have Sky Q what do you have Sky+, Sky Glass, Stream?
@AGodfrey123 Have you tried rebooting your main Q box ie
Do you have Sky+ then @AGodfrey123
Avatar for AGodfrey123
Sorry it is Sky Q actually
Yes done this, still encountering the same issue
@AGodfrey123
Try rebooting as suggested by @Laing1 then.
Hi @AGodfrey123
Thanks, I've rebooted but now I have no satellite signal. Any instructions on how to fix this?
Did you reboot or carry out the Reset Settings @AGodfrey123?
This message was authored by: Godfrey
@AGodfrey123  Do you have your own satellite dish or are you being served by a communal Integrated Reception System installation?
I did the Reset Settings
Communal dish
@AGodfrey123  Can you confirm that your LNB type is set to SCR
If it was showing  Wideband, change the LNB type to SCR and then remove the mains power from your Sky Q receiver for 20 seconds and then restore mains power to your Sky Q receiver.
@AGodfrey123 wrote:
Communal dish
Then you need change the LNB back to SCR @AGodfrey123
After doing this you need to power cycle the Q box
