11
This discussion topic has been answered Discussion topic: Split second sound drop out
Over the last few days we've noticed the audio drops out for a split second randomly but often. This is with both live and recordings although I'm going to have to check the Apps (Disney+ & Netflix at least) to see if it's across all feeds. Is this a known thing at the moment as we've only recently become aware of it.
Re: Split second sound drop out
hi @Anonymous
Not seen any increase of this in the forum.
hi @Anonymous
I've been listening to it all morning (live, recordings & rewound or paused content) and strangely haven't replicated it yet. This is without doing anything to the box at all, very perculiar.
I'm just recording one channel whilst watching another that was rewound a couple of minutes to see if it's the hard drive going. So far so good.
Sadly it's still there and was on Netflix this time, I'll have to check  with the wife on any other content as she watches it way more than myself.
I'll try the reset given above and if no joy I'll have to try the TV speakers rather than the soundbar for awhile to rule it out.
BTW, it's a Sky Q 1GB 32C009 box of uncertain vintage with audio output to the TV via HDMI and to the Yamaha YAS-103 soundbar via optical cable.
The reset appears to have resolved it although I couldn't say why, thank you.
This message was authored by: Coalescence
I have the same issue but doing a re-set did not fix the issue.  I run my sound through my cinema surround system /DVD player and have added a Y splitter to send the optical feed to both my Sky Q box and my Samsung TV. Could this be the cause or is it a software issue?
Try taking the splitter out of the loop - it could be causing the issue.
This message was authored by: adam1968uk
I watched some of the hull v hull kr rugby this evening on 401 and not a sign of any dropouts. So it's been sorted out or it's just the footie. Time will tell.
This message was authored by: Smudge7779
Also have this issue. Very annoying
This message was authored by: Meemeetiger
Same problem on our sky+hd box. Sound goes off for a couple of seconds every 5/10 minutes sometimes!
This message was authored by: Cls751
This has started happening on my parents hd box. Did anyone offer  a fix for Hd boxes?
