17
This discussion topic has been answered Discussion topic: Slow sky Q download
This message was authored by: spov
Slow sky Q download
Tell me sky aren't slowing your Q boxes down when you don't use there internet!
went with Lila connect as they are the only gigabit provider in my area and were also cheaper since have 500mbps internet with another provider my sky box has gone from downloading a 4K HDR show in a few minutes to taking well over an hour. My older internet (sky) was 58mbps None of the help guides have sorted this issue either telly me why with 10X quicker internet my box is downloading 100X slower!
Re: Slow sky Q download
@spov wrote:
Just ran a speed test using Netflix (not sure how reliable it is) but apparently it's getting 13.3 out of a portable 517 rest of the house all devices regardless off 2.4 or 5GHz connectivity are all reviving between 400-517 unsure why sky boxes are so different, totally unusable at the moment may have to hard wire it and pray the mrs doesn't see all the cables! Absolutely shocking bit of kit though if that all it's picking up total toss!
Hi @spov
How is your router connected to the Q box?
With non-Sky ISP you can only use 2.4GHz if connecting wirelessly.  A Sky router will use 5GHz.
Avatar for spov
No through wifi as it's always been my router outputs both 2.4 and 5ghz so that shouldn't be a problem it should still be picking up a much higher speed signal than before the box is also well ventilated
Your router may have 2.4 and 5GHz enabled but it will only use the former for your new provider.
That may not explain the difference but obviously the throughput will only be as fast as the slowest part of the complete route.   Published speeds are peak and won't be achieved from all sources.
Avatar for spov
Hi @spov
Something doesn't add up here.  An average 15Gb download is going to take over half an hour at that bandwidth.
Remember you can play them before they finish downloading fully.
Try Ethernet as you note but remember it's 2016 equipment so was designed well before today's home bandwidth was even dreamt about.
Avatar for spov
Managed to get it up to 25mbps wit doing this,  crudely wired it and got 350 so going have to get a super long Ethernet cable wait for the mrs to go to work
Or use powerlines
This message was authored by: simon194
If you don't have Sky as your broadband provider it's alway best to use an ethernet connection because the 2.4GHz band can be quite congested depending where you live.
_____________________________________________________
This message was authored by: Laconicsky
So if I turn off 2.4ghz on my non Sky router and only leave the 5ghz on you're saying my Sky Q box wont connect at all?
Tested this and it doesn't.
This message was authored by: DrJono
So what we are saying is Sky deliberately puts you on a slower bandwidth if you don't have Sky broadband. I thought this type of thing is anti consumer and illegal???
Answered - Go to Answer
