56
Discussion topic: Sky tv loses Internet connection
This message was authored by Chodley This message was authored by: Chodley
Re: Sky tv loses Internet connection
@SteveWBen wrote:
I've had a Sky Q TV box for just over a year and have Virgin broadband. The box is connected by Ethernet cable.
In the last few weeks I've been perpetually getting the message that WiFi connectivity is lost. I reset and it temporarily works, but then disappears again. I've rebooted to no avail.
I've not changed anything in my setup and all my other devices work fine.
Is there anything else I can try?
Have you disabled wifi in the hidden installer menu?
This message was authored by Muhsifa This message was authored by: Muhsifa
I tried everything to get Netflix running on my tv the internet's not connecting to the tv I updated the software on the tv but the problem is not being resolved
On the TV or on the Sky box?
This message was authored by SteveWBen This message was authored by: SteveWBen
I hadn't, but now have and it seems to have fixed it thanks! Odd that it was working in that mode for the best part of a year before it started to play up!
This message was authored by Pickastupidname This message was authored by: Pickastupidname
I've gone into the 'secret' menu and disabled 5G wifi to see if it makes any difference.
Sadly it didn't last. The connection is again being lost all the time
I wonder if Sky have put out a fix as the problem (for now at least) has gone away and the connection has been solid for the last couple of days
This message was authored by HPat This message was authored by: HPat
Cannot not get Internet reset, have unplugged and replaced  few times. Orange light on Internet on router
Unable to reset internet
This message was authored by stilts1202 This message was authored by: stilts1202
Hi,
If you read back through this blog you will see that you are not alone in experiencing this hugely frustrating problem and how some people have overcome it. In my case I had to get the router to only send 5khz (as opposed to both 2.4 & 5 kHz) Wi-Fi signals to my SkyQ box and all other devices. Apparently the dual signaling sends SkyQ into a frenzy and it drops the internet connection (whilst other devices continue to work ok). Unfortunately it was a Sky engineer who did the magic and he didn't want to take time to explain the methodology to a pensioner. He hard wired a new white Sky box of some description into my third party router.
This message was authored by LentheLock This message was authored by: LentheLock
Also experiencing this problem after switching from sky to Vodafone broadband. Tried all the suggestions in this stream to no avail; now going to try hardworking...
Make sure you disable wifi on the Sky boxes
