15
This discussion topic has been answered Discussion topic: Sky sd channels
This message was authored by: Trips+out
Sky sd channels
Hi sky community
I am bit confused by the changes that took place this week regarding skys SD channel switching off. I was under the impression that we didn't need to do anything but when the next step takes place in June this year do I need to upgrade my package to HD?. Thanks Ben.
Ben Edgett
Sky Q user
This message was authored by: nigea99 Answer
Re: Sky sd channels
@Trips+out wrote:
Can someone give me a list of channels that are on DVB-S2 at the moment please. Thanks Ben.
Although it may not contain all scrambled channels probably the best list I know of :
https://www.lyngsat.com/Astra-2E-2F-2G.html
(includes channels not availble via SKY as well)
As you will see all HD channels use DVB-S2
P.S. I haven' looked but it may not reflect the changes to SKY Sports & Cinema SD channels that switched over this week
Re: Sky sd channels
@Trips+out wrote:
Hi sky community
Depends what type of box you have
first thing first can you watch channel 5 in hd on 105 via your current box(es)?
Avatar for Trips+out
Level 4 icon
Re: Sky sd channels
I can access channel 5 in HD but my question is I am a bit worried about Sky turning off the rest of the sd channels in the future because I have got the HD add on do I need that HD add on to continue watching on my sky Q box?. Thanks Ben.
Ben Edgett
Sky Q user
Re: Sky sd channels
hi @Trips+out
SKY is not switching off more SD channels - it is changing the way they are transmitted using a method that the old SD boxes cannot decode - so if you have  SKY Q (which I am guessing you have as you posted in the SKY Q group) or a SKY HD box, this will not affect you
(Technically  the  'switch off' this week of the Sports and Cinema channels was actually removal from the EPG as the channels are still broadcasting to Ireland as some customers in Ireland do not subscribe to HD versions)
Re: Sky sd channels
@Trips+out  as things stand customers will still need the hd add on to watch entertainment channels in hd , sd versions of the entertainment channels will still remain for those that don't have the hd add on
we have not heard or seen anything yet to deviate from the above
Level 4 icon
Re: Sky sd channels
I have sky Q box so sky are not getting rid of any more SD channels in the future?.
Ben Edgett
Sky Q user
Re: Sky sd channels
@Trips+out  that's correct, but as I mentioned above if you want to continue to watch the hd version of the entertainment channels you still need the hd add on
Re: Sky sd channels
Not that we know of but as mentioned they are changing the way the SKY owned SD channels  are transmitted - which the SKY HD & SKY Q boxes can decode.
Level 4 icon
Re: Sky sd channels
So what sky entertainment channels are decode at this moment in time?
Ben Edgett
Sky Q user
Re: Sky sd channels
@Trips+out
The SD channels currently use DVB-S - they are switching to DVB-S2
Level 4 icon
Re: Sky sd channels
Ben Edgett
Sky Q user
Re: Sky sd channels
Re: Sky sd channels
@Trips+out  It's all sky branded channels in the signature package examples are
Sky Atlantic
Sky witness
sky max
sky documentary's
Sky comedy
and so on basically any entertainment channel starting with the prefix of sky
plus the ones on the link provided by @nigea99
Level 4 icon
Re: Sky sd channels
Can I just say thanks for all your support this evening
Ben Edgett
Sky Q user
Level 4 icon
Re: Sky sd channels
The reason why I posted about it again is trying to get sky's attention because I don't want to be in a situation where they announce such big  changes without warning.
Ben Edgett
Sky Q user
