Discussion topic: Unable to get sky or catchup demand
Message posted on 30 May 2024 09:28 AM
Changed to sky signature still using q box but now unable to connect to sky catchup and demand
On home says no Internet but WiFi broadband ok
Message posted on 31 May 2024 08:52 AM
Re: Unable to get sky or catchup demand
Message posted on 02 Jun 2024 08:53 AM
We are still looking to help you @Jayne69 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Message posted on 02 Jun 2024 09:51 AM
Hi @Jayne69
If you still have issues,
