1750
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky q switches off - 15/05
Locked
This message was authored by: Broseley89
Re: Sky Q box freezes up and screen goes black every 20mins
I don't want to replace our box, we would lose all our recordings.
This message was authored by: Malcolm1949
No connectivity on Sky Q
Since 905 pm last night no satellite connection , tried switching on and off at mains, and waiting , helpline hopeless .Now been off for 17 hours , have requested a call back but no acknowledgement from Sky . What else can you do especially as no one at Sky is responding?? Do they actually have any engineers? I have tried online and telephone helplines , various non responses or 'we are having technical problems'
This message was authored by: Dobber1234
Sky Q box went into standby mode completely unexpectedly last night twice
Hello everybody quick query last night twice within the space of an hour my sky Q box totally unexpectedly went into standby mode and wouldn't come out of it again. I had to switch the power on and off directly at the mains for this to resolve it was so annoying as I had to get assistance each time to be able to switch on and off the power at the wall. Does anyone know why this keeps happening? It hasn't happened to me very often but every few months it does it is so annoying. Does anyone know why this keeps happening? Turning it off and on at the mains does resolve the problem? However I had to do this twice last night does anyone have any advice?
This message was authored by: Julie156
Re: No connectivity on Sky Q
ditto! I can reset by unplugging at the mains but then turns off again after differing lengths of time!
This message was authored by: Emanuil
Try to unplug it for 5 minutes, there is currently a Sky Q issue that started last night and a longer power cycle fixes the issue.
This message was authored by: AndrewRhodes
just called sky and there was an issue that sounds like mine where sky q boxes were going into standby and they say its fixed now
This message was authored by: Mr+Messedaround
Playing back recorded programmes it plays for 10-15 minutes before switching off.
Recorded programmes play back for 10-15 minutes before switching off. I can reboot but when I reconnect I have to fast forward to where it cut out and it cuts out again after another 10-15 minutes
This message was authored by: WA14
My Sky Q started going into standby mode every 20 minutes last night (15 May).  From the helpful comments it seems I was far from alone and that Sky has now fixed the problem as at 16 May.
This message was authored by: Invisiblename
Re: Sky q switches off - 15/05
@K+Hill wrote:
Yes I did try the "recommended" fix last evening 5 times but it didn't work. It did work this morning
That's because the problem was fixed overnight
I am just another Sky customer!
@mlpnko wrote:
So no harm done but would be interested to know why the recording failed due to a "power cut" when there was no power cut.
Because whatever caused the problem at Sky made your box effectively 'freeze' during which recordings would have temporarily stopped until you did the power cycle, and it would have iterpreted that as a power cut
Correct
There was a major system-wide problem last night which has now been sorted.  You should find that one more power off at the wall, wait 30 seconds, than power back on should sort it
This message was authored by: SteveC285
Box freezes
When watching a playback recording, the box freezes and I get a black screen, the box shows has a continuous circular blue circle
The remote will not respond until I cut the power and restart.
I am able to use the recorded programs again, but will go wrong again between 10 and 30 mins
What can I do?
This message was authored by: Dee140
Re: Tv on Sky Q main box goes black and I get a spinning circle for a few seconds, totally random!
This is happening mine too, have updated and still happening. Did you find a resolve?
This message was authored by: Clare2812
The problem is definitely not fixed, - mine is still down despite matter allegedly being resolved. And yes, i have tried all recommendations to fix it
Locked
Answered - Go to Answer
