Discussion topic: Sky q box stuck on accessibility screen
This message was authored by: Amf2
  • Sky q main box is stuck on accessibility screen. The mini q box is also unresponsive to remote but is stuck on the menu screen. Tried resetting and repairing both remotes. Nothing happened. Tried plugging out router, mini q box working, main q box still stuck. This is for past 2 weeks. Every time sky box is put in stand by same thing happens. Any suggestions? All other equipment linked to router work fine.
Re: Sky q box stuck on accessibility screen
Hi @Amf2
Try a Reset Settings in the main Q box hidden menu.
Avatar for Amf2
Hi, problem is the main q box remote is completely unresponsive. I had a spare sky remote... that won't pair either
Hi @Amf2
Reset your Qbox remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the Q box.
See then if can get your Q box working with the remote in infrared
Once you get the box working make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
@Amf2
Sky have suggested the following…
  • Unpair their Sky Q remote from the box by holding 4&6
  • Wait for the remote to flash
  • Then dismiss the information screen "Skip & set up later"
  • Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Amf2
Thanks all. None of the suggestions worked this time. Engineer booked to come out
This message was authored by: PATTINSON
Thanks a lot. This worked for me.
This message was authored by: Yus82
Take batteries out, keep the select button pressed down and reinsert the battles whilst select button is pressed down. This worked after trying the above.
