Discussion topic: Sky q box stuck on accessibility screen
Message posted on 26 Jul 2024 07:12 PM
- Sky q main box is stuck on accessibility screen. The mini q box is also unresponsive to remote but is stuck on the menu screen. Tried resetting and repairing both remotes. Nothing happened. Tried plugging out router, mini q box working, main q box still stuck. This is for past 2 weeks. Every time sky box is put in stand by same thing happens. Any suggestions? All other equipment linked to router work fine.
Message posted on 26 Jul 2024 07:20 PM
Re: Sky q box stuck on accessibility screen
Hi @Amf2
Try a Reset Settings in the main Q box hidden menu.
Message posted on 26 Jul 2024 07:31 PM
Hi, problem is the main q box remote is completely unresponsive. I had a spare sky remote... that won't pair either
Message posted on 26 Jul 2024 07:39 PM
Hi @Amf2
Reset your Qbox remote by pressing and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes. However the remote must be pointed directly at the Q box.
See then if can get your Q box working with the remote in infrared
Once you get the box working make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Message posted on 26 Jul 2024 08:14 PM
Sky have suggested the following…
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Message posted on 28 Jul 2024 09:10 AM
Message posted on 04 Feb 2025 08:59 PM
Thanks a lot. This worked for me.
Message posted on 30 Mar 2025 11:41 AM
Take batteries out, keep the select button pressed down and reinsert the battles whilst select button is pressed down. This worked after trying the above.
