Discussion topic: Sky q box stuck on accessibility screen
This message was authored by: Amf2
  • Sky q main box is stuck on accessibility screen. The mini q box is also unresponsive to remote but is stuck on the menu screen. Tried resetting and repairing both remotes. Nothing happened. Tried plugging out router, mini q box working, main q box still stuck. This is for past 2 weeks. Every time sky box is put in stand by same thing happens. Any suggestions? All other equipment linked to router work fine.
Re: Sky q box stuck on accessibility screen
Hi @Amf2
Try a Reset Settings in the main Q box hidden menu.
Avatar for Amf2
Hi, problem is the main q box remote is completely unresponsive. I had a spare sky remote... that won't pair either
Hi @Amf2
Reset your Qbox remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the Q box.
See then if can get your Q box working with the remote in infrared
Once you get the box working make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
@Amf2
Sky have suggested the following…
  • Unpair their Sky Q remote from the box by holding 4&6
  • Wait for the remote to flash
  • Then dismiss the information screen "Skip & set up later"
  • Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Avatar for Amf2
Thanks all. None of the suggestions worked this time. Engineer booked to come out
This message was authored by: PATTINSON
Thanks a lot. This worked for me.
This message was authored by: Yus82
Take batteries out, keep the select button pressed down and reinsert the battles whilst select button is pressed down. This worked after trying the above.
