Discussion topic: Sky q box stops working
This message was authored by: Sian275
My sky q box keeps stopping working almost every morning and randomly throughout the day. There is power to the box the light is green but we have no TV. The only way to fix it is to turn the box off and then back on. As you can imagine doing this daily sometimes more than once a day is very annoying. We have even just had the box replaced and set up by an engineer but this had not solved the problem. We are with BT broadband but when checking g the network is connected the network name is Sky......   anyone have any ideas how to fix this?
Re: Sky q box stops working
@Sian275
Any messages that come up?
I am NOT a Sky Employee
Avatar for Sian275
It is saying there is no power to the box but it is definitely on and the power light is green.
Hi @Sian275
You can ignore the Network name shown in the Q box settings as this is likely to be the Q WiFi mesh name and not necessarily the Network to which it is connected.
Next time you have the Q box Working check that it is on the latest software.  If not update it.
https://www.sky.com/help/articles/sky-software-updates
If you still have the issue
Avatar for Sian275
We have tried all this and been provided with a new box.
Could this be an Internet issue rather than the box itself?
This message was authored by: LK2019
Hi did you ever get a answer as to why this keeps happening?? I've had this issue now the last month, I've had 2 new boxes as well and still no answer as to why this happens .. very frustrating always having to turn of at the mains power everytime to restart the skyq box
chris
This message was authored by: Jon_c_h
Happens to me , same issue, had three boxes but it never fixes the issue.
Avatar for Sian275
We now put the sky box in standby every night orange light and it works every morning now. I don't know if putting it in stand by makes a difference or if it just randomly started working properly again.
This message was authored by: richard+TRB
Hi, had to replace failed q box ever since newbox??? Has to be rebooted daily, recording memory freezes, miniboxes disconnect at random rebootof main box clears faults temporarily. Are the new boxes u/s or does one keep changing until a good one is received??
This message was authored by: Jflo12
Same. It's really frustrating and no one seems to know why.
Avatar for Sian275
We swit have off the TV and the sky q box goes into standby. We don't have issues at the moment and hope ut stays that way.
This message was authored by: Scotser
Was this ever solved?? Happened to me. 2 boxes so far. What is going on.
