Discussion topic: Sky multi room not working
This message was authored by JenniCawsey This message was authored by: JenniCawsey
We have 3 tvs with sky in this house and only the main one is working it has been like this all weekend and we don't have freebies so unable to watch tell at all in 2 of the rooms
This message was authored by SKY1992bf This message was authored by: SKY1992bf
Re: Sky multi room not working
@JenniCawsey  Check your bill online to see if multi screen is still showing
Please note: I am just a sky customer not a employee - posts from sky employees are clearly marked as such
Hi @JenniCawsey
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
JenniCawsey
Thank you I have tried rebooting all of them multiple times but still no difference
Hi @JenniCawsey
Try a Reset Settings in the main Q box hidden menu.
JenniCawsey
Thank you I have looked on MySky and it is still showing under my products and also I paid for it this month
