Discussion topic: Sky box will not connect to Wi-Fi
Message posted on 08 Jul 2024 06:36 PM
Sky box will not connect to Wi-Fi and followed instructions to reset but to no avail. Help required?
Message posted on 08 Jul 2024 07:18 PM
Re: Sky box will not connect to Wi-Fi
Hi @Suski
