Discussion topic: Sky multi room not working
Message posted on 08 Jul 2024 06:51 PM
We have 3 tvs with sky in this house and only the main one is working it has been like this all weekend and we don't have freebies so unable to watch tell at all in 2 of the rooms
Message posted on 08 Jul 2024 07:00 PM
							Re: Sky multi room not working
@JenniCawsey Check your bill online to see if multi screen is still showing
Message posted on 08 Jul 2024 07:06 PM
Hi @JenniCawsey
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 08 Jul 2024 07:18 PM
Thank you I have tried rebooting all of them multiple times but still no difference
Message posted on 08 Jul 2024 07:19 PM - last edited: 08 Jul 2024 07:19 PM
Hi @JenniCawsey
Try a Reset Settings in the main Q box hidden menu.
Thank you I have looked on MySky and it is still showing under my products and also I paid for it this month
