24
This discussion topic has been answered Discussion topic: Sky mini box not working
This message was authored by: MAVTAW
Re: Sky mini box not working
Yes it is connected
Still no signal after doing all that.
This message was authored by: kazza77
Hi any help sky mini box stopped working I've rebooted sky q reset sky mini pressed button on front n red light staying on and xant get it to work
This message was authored by: Di123
Re: Sky mini box not working all leads are connected and I have re booted 3 times. The second box in
Why is my sky box showing no signal but a second box in another room is fine ?
This message was authored by: Nicola96
It's saying it's not connected to sky q box or the internet been like that since yesterday
This message was authored by: beene1967
The  box itself won't turn on at all no lights nothing
This message was authored by: Leanna1977
My sky mini box will not go past blue screen where it says when your screen goes blank press the home button it just keeps rebooting from that point tried the reset button on the back all is connected to the Internet and the mine box down stairs even tried disconnecting the leads and still the same
This message was authored by: Sky199712345
My mini box turns on but not getting anything else I keep getting error  MR104
I have tried all the trouble shooting and it's still not working
@Sky199712345 its hard to diagnose when you have said you have trried allthe troubleshooting it would be easier if you could say what troubleshooting you have tried but incase you haven't tried
Have you tried rebooting your main Q box ie
then
rebooting your mini box
This message was authored by: thraedgold
The mini box is not working i'v tried all the sky suggestions and it still not working
Answered - Go to Answer
