24
This discussion topic has been answered Discussion topic: Sky mini box not working
This message was authored by: Dandy2336
Everything is connected to internet
Re: Sky mini box not working
@Dandy2336 wrote:
Just says no signal
Hi @Dandy2336
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Failing this either
  • the HDMI lead is not correctly connected or faulty
  • The TV set is not switched to the correct input
Hi @Dandy2336
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for Dandy2336
It just still comes up no signal
Hi @Dandy2336
Check that the HDMI cable is securely connected to TV and Q box.
Also check that you have selected the correct HDMI input for the Q box on your TV.
When you rebooted the mini did you get any message on your TV?
Just says no signal
@Dandy2336 wrote:
Just says no signal
Hi @Dandy2336
Press
Home 1 0 8 0 Home
Failing this either
Problem solved thanks
This message was authored by: davus4
Sky q mini box keeps stalling. Finally after about 40 minutes, a message has popped up saying connectivity issue between main box and mini box. No solution  given
This message was authored by: Geoffwhitfield
Sky mini box has technical fault I can get listings and see what recordings are available but when I select anything I get 'technical fault. All boxes ticked in settings on both boxes and other mini box works ok
This message was authored by: Philip811
Still won't connect even using that button.
This message was authored by: Nick34
Tv switched but no lights on mini box other thsn small red light glow from rear, indicating power on but no other lights showing in front
Sky TV working fine on main set. All green lights on Q Plus extension box. No Lights showing when buttons pressed on mini black box on second TV in Kitchen wwhich is unable to connect. Small light on back of black mini Box but no lights on fron when buttons pressed. Worked fine for months but no connection since yesterday.
This message was authored by: Paul165
My mini box isn't lighting up check fuse still not coming on
This message was authored by: Salcab
Hi
my sky mini box has stopped working and I can't get a number anywhere to call !!!
I've tried it in another tv and nothing , it does say on the tv where the main sky box is connected the it's "connected" . When the plug is switched on the red light comes on then immediately goes off . Any ideas ? Thank you
@Paul165 I'm having the same issue , have you resolved yours ?
