Discussion topic: Skybox
Message posted on 15 Nov 2024 01:20 PM
Skybox
Every morning I get software update step 1 of 2. I takes 10 minutes to clear it then it's back the following day
Message posted on 15 Nov 2024 01:32 PM
Re: Skybox
Hi @David390
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
