Discussion topic: SKY Q mini box, blue screen says no video signal
Message posted on 14 Nov 2024 09:39 AM
SKY Q mini box in bedroom doesnt seem to be working. Got blue screen that says NO VIDEO SIGNAL. Tried rebooting & resetting mini box, main router, booster & main SKY Q box but still not working. Everything else works ok
Message posted on 14 Nov 2024 10:16 AM
Re: SKY Q mini box, blue screen says no video signal
Hi @jash58
What colour is the led on the front right of the mini box?
If it is still amber have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
If the led is green then, first make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Message posted on 14 Nov 2024 10:25 AM
Thank you Oldfella
The LED is green on the minibox
I will try your suggestion when I get home
Many thanks
Message posted on 14 Nov 2024 10:43 AM
Hi Oldfella
just to clarify, the Home 1080 Home. Is that to be done on the main Q box or the mini box?
Message posted on 14 Nov 2024 11:29 AM - last edited: 14 Nov 2024 12:02 PM
@jash58 wrote:
Hi Oldfella
On the mini box @jash58
First make sure that the Television set is switched on and is switched to the HDMI input to which the min box is connected.
Then with the mini box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the mini box remote control.
Message posted on 15 Nov 2024 01:50 PM
Thanks for your help. Tried this & managed to get screen up & running. Now saying no internet signal. Tried all suggestions on the forum to get it sorted but have had to resort to booking an Engineer
Message posted on 15 Nov 2024 01:56 PM
Hi @jash58
Have you tried
Reboot the mini as above.
