Discussion topic: Sky box saying no signal
This message was authored by Stephens+joy This message was authored by: Stephens+joy
Hi all , switched Tv of last night. As normal, got up switched Tv on & Sky , but Sky saying no signal?. I've taken the Sky card out blow on it . Turned back on . Just saying the same? I've had a look at cable out side, alls good, yet still no Sky
This message was authored by Mark39 This message was authored by: Mark39
Re: Sky box saying no signal
No signal? Or no satellite signal? Have you tried restarting your Q box by turning off at the plug for 30 seconds or so?
Stephens+joy
No Digital Tv signal available
Hi @Stephens+joy
If it is a No Signal message then it is from your TV set.
First make sure that HDMI lead between TV and Sky box is correctly located at both ends.
Then with the TV switched on make sure it is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Stephens+joy
Yes unplug it but just saying the same thing
Stephens+joy
Yes it be checked the cable is in n both ends
Stephens+joy
Yes I've done all ,, unplug/ checked the cables Tv & sky box, I switched it off as normal last night,, as have been past 5 years,, no one else has been here
Does the Q box have a green led @Stephens+joy ?
Stephens+joy
Yes Green light is on, preset home & tried putting in 1080 still same message no n Tv
Stephens+joy
Just the lead Sky fitted,, no one else can touch the tv or sky box , & no I don't own a Cat lol
Hi @Stephens+joy
Did you press
Home 1 0 8 0 Home
ie 6 button presses.
Stephens+joy
Just tried Home 1080Home just same message & Green light
Hi @Stephens+joy
Do you have another HDMI lead you can try?
Stephens+joy
Hi Yes I've just fitted & still same thing on tv screen
Hi @Stephens+joy
Only other thing I can suggest is that you try another HDMI input on your TV set.
Failing that it looks like you need a Sky Engineer
Edit
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147?
