Discussion topic: Sky Q remote broken
This message was authored by: Sarah777
Sky Q remote broken
The remote no longer works
Re: Sky Q remote broken
Either buy a new one from many retailers or ask Sky for a replacement: https://www.sky.com/help/forms/replaceremote
Hi @Sarah777
Failing this if you still need a new remote
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
This message was authored by: PeteRG41
And check the obvious and simple thing first - replace the batteries in the remote with new ones.
____
Pete.
