Discussion topic: Sky Q mini
Message posted on 16 Oct 2024 07:57 PM
Sky Q mini
I have purchased a second Sky q mini but it is saying I have the maximum number of boxes in use which is only one.
Message posted on 16 Oct 2024 08:02 PM - last edited: 16 Oct 2024 08:03 PM
Re: Sky Q mini
You don't purchase mini boxes. They are loaned to you by Sky. Did you obtain this box from Sky?
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Message posted on 16 Oct 2024 08:06 PM
Re: Sky Q mini
@Irene721 what Sky Q main box do you have is it a 1TB that cannot receive UHD as the original 1TB boxes although you can have upto 4 mini boxes loaned from Sky you can only view on 1 at a time.
You would need to upgrade to a newer 1 TB box or any 2 TB box will allow you to view 2 mini boxes at the same time
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 16 Oct 2024 08:07 PM
Re: Sky Q mini
If that is they case why do you have the option to purchase more at £50 a time. My hardware version say 32D00E
Message posted on 16 Oct 2024 08:12 PM - last edited: 16 Oct 2024 08:15 PM
Re: Sky Q mini
I think that's a mini version, you need the Q version.
also it's not "purchase", just bear that in mind, you have to give them back when your contract is up.
You can use them 1 at a time and that's a rare but valid use pattern for some people, that's why they let you add one even if your Q box version can't support them simultaneously.
Message posted on 16 Oct 2024 08:14 PM
Re: Sky Q mini
- They are sky Q mini boxes
Message posted on 16 Oct 2024 08:17 PM
Re: Sky Q mini
When I say Q, I mean the main box. What version is that?
Message posted on 16 Oct 2024 08:19 PM
Re: Sky Q mini
@Irene721 wrote:If that is they case why do you have the option to purchase more at £50 a time. My hardware version say 32D00E
@Irene721 It's not a purchase option but a loan option
Message posted on 16 Oct 2024 08:20 PM
Re: Sky Q mini
Not sure. The hardware is 32C006
Message posted on 16 Oct 2024 08:21 PM
Re: Sky Q mini
Then you have a non UHD 1TB that only supports 1 active mini box.
Message posted on 16 Oct 2024 08:24 PM
Re: Sky Q mini
How do you get rhe correct box
Message posted on 16 Oct 2024 10:17 PM
Re: Sky Q mini
@Irene721 wrote:How do you get rhe correct box
Call Sky and explain the problem. They should upgrade you. Don't forget to keep your viewing card and you will of course lose your recordings.
