Discussion topic: Sky Q mini
This message was authored by: Irene721
Sky Q mini
I have purchased a second Sky q mini but it is saying I have the maximum number of boxes in use which is only one.
Re: Sky Q mini
@Irene721
You don't purchase mini boxes. They are loaned to you by Sky. Did you obtain this box from Sky?
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Re: Sky Q mini
@Irene721 what Sky Q main box do you have is it a 1TB that cannot receive UHD as the original 1TB boxes although you can have upto 4 mini boxes loaned from Sky you can only view on 1 at a time.
You would need to upgrade to a newer 1 TB box or any 2 TB box will allow you to view 2 mini boxes at the same time
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Irene721
Re: Sky Q mini
If that is they case why do you have the option to purchase more at £50 a time. My hardware version say 32D00E
Re: Sky Q mini
I think that's a mini version, you need the Q version.
also it's not "purchase", just bear that in mind, you have to give them back when your contract is up.
You can use them 1 at a time and that's a rare but valid use pattern for some people, that's why they let you add one even if your Q box version can't support them simultaneously.
Avatar for Irene721
Re: Sky Q mini
  • They are sky Q mini boxes
Re: Sky Q mini
When I say Q, I mean the main box. What version is that?
Re: Sky Q mini
@Irene721  It's not a purchase option but a loan option
Avatar for Irene721
Re: Sky Q mini
Not sure. The hardware is 32C006
Re: Sky Q mini
@Irene721
Then you have a non UHD 1TB that only supports 1 active mini box.
Avatar for Irene721
Re: Sky Q mini
How do you get rhe correct box
Re: Sky Q mini
Call Sky and explain the problem. They should upgrade you. Don't forget to keep your viewing card and you will of course lose your recordings.
