2
This discussion topic has been answered Discussion topic: Sky Q mini box
This message was authored by: Lsj1
Sky Q mini box
I have spent an hour trying to fix this!. Currently my sky Q mini is stuck on a screen that says accessibility on sky Q and I cannot move it on. I cannot move the settings or skip and set up later. The remote seems to still work and have replaced the battery. I'm getting very frustrated and cannot speak to anybody at Sky to assist
This message was authored by: nigea99 Answer
Re: Sky Q mini box
hi @Lsj1
This message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only (so must have line of sight of the box)
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
Re: Sky Q mini box
hi @Lsj1
Avatar for Lsj1
Re: Sky Q mini box
Thank you. That sorted the issue out. I spent an hour last night and got very frustrated. And that took 5 mins to fix.
