Discussion topic: Sky Q download
Message posted on 24 Sep 2025 04:42 PM
Re: Unable to download Flipping Bangers series 2 - on Q
No my isp is luckily not sky
And yes every thing else downloads
Message posted on 24 Sep 2025 04:44 PM
Re: Sky Q will not download programs
I've moved your post into a thread discussing this. Some are having similar issues on Sky+. The common denominator seems to be having TalkTalk broadband.
Message posted on 24 Sep 2025 04:46 PM
That wasn't the question. Is TalkTalk your broadband provider?
Message posted on 24 Sep 2025 04:49 PM
Hi. Everyone
The 1.0.0.1 instead thing worked. Thank you 😊
Message posted on 24 Sep 2025 05:04 PM
Re: Sky Q download
Have you an eero router?
if so go to network controls then turn advanced security off
Message posted on 24 Sep 2025 05:19 PM
Re: Sky Q download
No just a normal router
Message posted on 24 Sep 2025 05:23 PM
Re: Sky Q download
I've marked as "the Answer" one of the many posts in here that included a simple workaround, in the vain hope people will read it.
Message posted on 24 Sep 2025 05:24 PM
Re: Sky Q download
You may have to go into your routers settings to disable security
Message posted on 24 Sep 2025 05:25 PM
Re: Sky Q download
@Steve18921 wrote:You may have to go into your routers settings to disable security
In addition to changing DNS?
Message posted on 24 Sep 2025 05:26 PM
Re: Sky Q download
I didn't change the ddns
Message posted on 24 Sep 2025 05:27 PM
Re: Sky Q download
@Steve18921 wrote:I didn't change the ddns
Interesting. And just changing that worked?
what does that option do?
and you are on TalkTalk?
Message posted on 24 Sep 2025 05:29 PM
Re: Sky Q download
Yes I'm on talk talk
the router was blocking access to skys domain in the security option hence why the no broadband message appeared on the attempted download
Message posted on 24 Sep 2025 05:39 PM
Re: I am teyingvto downliad a programme i have inrernet vonnection
Yes i am with talk talk
Message posted on 24 Sep 2025 05:40 PM
@Norma59 wrote:Yes i am with talk talk
Change your DNS as per the answer post in here.
Message posted on 24 Sep 2025 05:41 PM
Re: Sky Q download
@Steve18921 wrote:Yes I'm on talk talk
Sky's domain specifically? Why would it do that? Are you saying that's a default behaviour on these eero routers?
