234
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Q download
Locked
This message was authored by: Steve18921
Re: I am teyingvto downliad a programme i have inrernet vonnection
That didn't work for me but disabling the routers new security blocker did the job instantly
Re: Sky Q download
They've loads of security features installed
at first mine blocked any sponsored links till I disabled that then this problem appeared after the new update
This message was authored by: Norma59
Re: Sky Q download
What is dns
This message was authored by: Smokie+19
Re: Sky Q download
Can you tell me how to do this please not very good with tec, Thanks
Re: Sky Q download
Re: Sky Q download
@Steve18921 wrote:
And the only thing that's changed is that 2nd option was switched on before?
Sounds like maybe 2 different issues.
Re: Sky Q download
Yeah the advanced security was on and it blocks certain sites it
as soon as I turned it off the downloads started
Re: Sky Q download
That's ok for eero routers have any idea to change on a normal router please
Re: Sky Q download
@Norma59 wrote:
What is dns
Domain name services. It's the global directory that makes the entire internet work, it's been around since 1983 as the way that internet devices turn names like "www.sky.com" into numeric IP addresses
the problem is when one of the copies of the directory (in this case it appears to be TalkTalk's) doesn't correctly update a change of address so your requests for downloads get sent to the wrong place/likely a non-existent address.
to change which dns server you are using for lookups, do this;
  1. Press the ‘Home’ button on your Sky remote
  2. In the left-hand menu scroll to and select ‘Settings’
  3. Select ‘Network connection’
  4. Select ‘Network setup’
  5. Click on ‘Edit’
  6. Select DNS server from this list (IP address, Subnet mask, Router, DNS server)
  7. Write down the existing entry so you can re-enter it later when this all blows over
  8. Replace it with 1.1.1.1 or 8.8.8.8, either will do
  9. Hit Confirm
  10. power off your sky box for 30seconds. This step seems overkill but it's in the guide I just googled
You don't need to change it on your router, since this seems to be an issue specific to Sky download services, but you could set it there too if you know how, wouldn't break anything.
Re: Sky Q download
Thanks I'll try when I get back home
Re: Sky Q download
Hi, is this a sky download issue or do I need to contact talktalk for them to resolve the problem
Re: Sky Q download
You could ask talk talk to remove any security features attached to your router
Re: Sky Q download
It's affecting people who don't have that eero router though. Like I say, it might be two different issues with the same symptoms.
I would just change DNS, then try the security setting thing that worked for you, and not bother wasting my time contacting either of them.
Re: Sky Q download
It's a TalkTalk (no other ISP seems affected) issue that impacts Sky's download service.
This message was authored by: Gav51
Re: Sky Q download
On Talk Talk. No need to change DNS for me - on EERO router turn off AdBlocking and Advanced Security - worked straight away.
Locked
Answered - Go to Answer
