234
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Q download
Locked
This message was authored by: Wibbly-Woo
Re: Unable to download Flipping Bangers series 2 - on Q
No my isp is luckily not sky
And yes every thing else downloads
Re: Sky Q will not download programs
@MrFoxLCFC
I've moved your post into a thread discussing this. Some are having similar issues on Sky+. The common denominator seems to be having TalkTalk broadband.
@Wibbly-Woo
That wasn't the question. Is TalkTalk your broadband provider?
This message was authored by: Gordonpress
Hi. Everyone
The 1.0.0.1 instead thing worked. Thank you 😊
This message was authored by: Steve18921
Re: Sky Q download
Have you an eero router?
if so go to network controls then turn advanced security off
This message was authored by: Smokie+19
Re: Sky Q download
No just a normal router
Re: Sky Q download
I've marked as "the Answer" one of the many posts in here that included a simple workaround, in the vain hope people will read it.
Re: Sky Q download
You may have to go into your routers settings to disable security
Re: Sky Q download
In addition to changing DNS?
Re: Sky Q download
I didn't change the ddns
Re: Sky Q download
Interesting. And just changing that worked?
what does that option do?
and you are on TalkTalk?
Re: Sky Q download
Yes I'm on talk talk
the router was blocking access to skys domain in the security option hence why the no broadband message appeared on the attempted download
This message was authored by: Norma59
Re: I am teyingvto downliad a programme i have inrernet vonnection
Yes i am with talk talk
Change your DNS as per the answer post in here.
Re: Sky Q download
Sky's domain specifically? Why would it do that? Are you saying that's a default behaviour on these eero routers?
Locked
Answered - Go to Answer
