6
Discussion topic: Sky Q banner timing
This message was authored by Phild52 This message was authored by: Phild52
Sky Q banner timing
Hi. Can anyone please point me in the direction of the sequence on my sky q control to alter time time of the banner on channels.....thank you
This message was authored by Daniel0210 This message was authored by: Daniel0210 Answer
Re: Sky Q banner timing
@Phild52
What banner are you referring to?
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
hi @Phild52
I don't think there is any such setting on SKY Q
BTW you can just press the Back/Dismiss to remove it immediatly you press the button rather than wait
@Phild52
This message was authored by PandJ2020 This message was authored by: PandJ2020
Sometimes the channel banner may stick permanently.  A reboot of the box will fix it.
Otherwise, it's the back button as above or wait around 5 seconds.
Q's UI is not configurable...
I am just another Sky customer and my views are my own
Phild52
The banner that pops up when you change channel
Phild52
I think your right.... you can only do it on the sky+ control....thanks anyway👍
This message was authored by none100 This message was authored by: none100
Sky Q rubbish.. I should have stuck with Sky+ box. Why can't the software give you all the same options we had with Sky+/hd box... Another not It upgrade...
