Discussion topic: Sky mini box has no signal and although Ee have rest it it is not working
Message posted on 27 Jul 2023 12:05 PM
Sky mini box not working there is no issues with main Q box. We have tried to reset it but is is not working
Message posted on 27 Jul 2023 12:12 PM
Re: Sky mini box has no signal and although Ee have rest it it is not working
Hi @Shieby
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
