This discussion topic has been answered Discussion topic: Sky Q banner timing
Message posted on 04 Jun 2023 08:04 PM
Hi. Can anyone please point me in the direction of the sequence on my sky q control to alter time time of the banner on channels.....thank you
Message posted on 04 Jun 2023 08:12 PM
What banner are you referring to?
Message posted on 04 Jun 2023 08:10 PM - last edited: 04 Jun 2023 08:13 PM
Re: Sky Q banner timing
hi @Phild52
I don't think there is any such setting on SKY Q
BTW you can just press the Back/Dismiss to remove it immediatly you press the button rather than wait
Message posted on 04 Jun 2023 08:29 PM
Sometimes the channel banner may stick permanently. A reboot of the box will fix it.
Otherwise, it's the back button as above or wait around 5 seconds.
Q's UI is not configurable...
Message posted on 04 Jun 2023 09:02 PM
The banner that pops up when you change channel
Message posted on 04 Jun 2023 09:05 PM
I think your right.... you can only do it on the sky+ control....thanks anyway👍
Message posted on 27 Jul 2023 12:03 PM
Sky Q rubbish.. I should have stuck with Sky+ box. Why can't the software give you all the same options we had with Sky+/hd box... Another not It upgrade...
