Discussion topic: Sky Q On demand failed,location check failed - Starlink
Message posted on
16 Sep 2024
06:31 AM
- last edited:
03 Oct 2024
09:22 AM
by
Daniel-F
This problem has just started to happen within the last week. I am using Starlink as my ISP. The assigned IP by Starlink is coming back as a UK based IP address. So why is Sky throwing this error? Its their software that must be checking the IP address pool. There is no point in 'rebooting' routers. Or turning things on and off again because this won't solve the issue.
Time for a rumble with Sky.
Moderator note: Amended Subject to better reflect query
Message posted on 16 Sep 2024 04:11 PM
Re: Sky Q On demand failed,location check failed!
This started to happen last weekend with my Starlink ( UK) too. Called Sky, senmt a new box, same problem again...no demand and no download. Speaking to them this afternoon but got cut off, testing my patience.
Message posted on 16 Sep 2024 04:15 PM
Its all Skys configuration. They do not have Starlinks full address pool in their list of UK IP addresses. Its their software that is issuing the error message, therefore its Sky's issue. No new boxes or reboots or engineers visits is going to solve the problem.
Message posted on 16 Sep 2024 04:18 PM
I thought that might be the case, I just dont undersatnd why it has worked perfectly well for 2 years and now has an issue, many thanks for your information and expertise.
I really dont know how to get them to add my IP adress though
Message posted on 16 Sep 2024 06:03 PM
As it happens... I attempted to access a 'UK Only' website this afternoon and it threw an error basically saying I wasnt in the UK.. so perhaps it is Starlink after all. I have raised a ticket with Starlink this afternoon. I'll keep you posted.
Message posted on 17 Sep 2024 06:18 AM
An update: When I checked my WAN IP address (209.198.129.246) with iplocation.net, it showed the location of Ukraine, however other databases showed UK. This morning, the location data is now correct and showing as UK. Sky is now behaving and I can now download shows. Seems to be fixed.. for now.
Message posted on 17 Sep 2024 07:20 AM
I have checked mine, it is asserting its a UK address. However, I note that my TV is linked to a node ( private) and not the main router. May this be the issue?
Message posted on 17 Sep 2024 10:17 AM
OK.. After finally getting through to someone who knew their subject matter.. here is the reponse I have from Starlink support.
"Paul, Thank you for confirming. This is a reported and known issue at the moment.
You can attempt to use a free VPN (Such as Opera Web Browser) as a work around in the moment.
I do not know an exact time frame on this fix, but we lok forward to offering a solution. "
So... I think a possible solution is to reboot the Starlink (not just the router) via the app and hope that it reallocates you a WAN IP address that IS a UK registered IP. Its an 'administration' issue for Starlink to solve.
Message posted on 17 Sep 2024 11:06 AM
That is of a great help, I too have now contacted Starlink in the same manner you have, and have asked to communicate with a person not the bot.
Rebooting unsuccessful.
Many thanks for your help
Message posted on 23 Sep 2024 08:35 AM
Did you get it resolved, same thing happened to me and got a new box Friday and the same problem. Also have a Starlink. Thanks
Message posted on 23 Sep 2024 08:38 AM
It's not a fault with your Sky box.
You need to reboot your Starlink dishy (not the router). This will then hopefully allocate you a WAN IP address which Sky recognise as a UK based address.
I rebooted Starlink via the app, made sure the TV was li led to router and not a node and all working ok now. Hope this helps
Message posted on 23 Sep 2024 08:40 AM
I will try it - Thanks
Message posted on 23 Sep 2024 02:30 PM
Failed location check
I have sky Q for years & with starlink broadband for a year. . It's hardwired. I have a deco mesh system & the Q is hardwired to the nearest node I used to occasionally get a failed location rejection which was annoying but livable
the past weekend every single download I have had a failed location error.. after contacting Sky they blamed Starlink. Starlink do not offer changes in IP addresses end of. I have a Sky Q box which I can only record and watch live tv on. I really don't know what else to do. I have rebooted both the sky & broadband on several occasions I even dug out an old sky booster to see if it would work with that which didn't work either.
Any help most welcome. I am not tech savvy but I'm not clueless either.
Message posted on 23 Sep 2024 09:53 PM
Re: Failed location check
I also have Starlink (and have had it since it was first available) and have just started to get this problem with my SKY Q!
SKY better sort this pronto otherwise I will be cancelling my contract!
