Discussion topic: Setting up a projector
Avatar for Glenn21
This message was authored by: Glenn21
Re: Setting up a projector
Yes, I will give that a shot, willing to try anything
Hi @Glenn21
Cannot find any confirmation that your Projector supports HDCP 2.2.
As this is normally required for 4K content most modern 4K TV sets will support this.
However your projector is not 4K capable and is 1080p resolution.
As 1080p doesn't need HDCP 2.2 support it's possible that your projector also does not support HDCP 2.2 which a Q Main box requires.
It's specification says it includes HDCP but does not clarify which version.
If it will not work with a shorter HDMI (3 or 4M) then I suppose you could consider using a Sky Q mini which could possibly be located nearer to the projector and could therfore use a shorter HDMI cable.  Minis will not require HDCP 2.2 support.
Avatar for Glenn21
I have a mini in the other room which I use for multi room, I could swop the boxes around and it may work.
Hi @Glenn21
You could certainly try your Multiroom mini with the projector.
However you cannot swap a mini position for the main Q box position because the main Q box needs the cable connection from the Satellite dish.
Avatar for Glenn21
Yes thats a good point.......I will give all these options a go later.
Avatar for Glenn21
So, I've got it work and I'm believing it's a HDMI issue, I plugged the projector into the sky  box with the sky HDMI cable and it worked.....obviously my 8K Amazon HDMI cable isn't good enough or the wrong one, my next question is can anyone recommend an 8 meter HDMI cable? It will HD only not UHD..  ..Thank you everyone for your help.
This message was authored by: RoRo39
@MightyQuinn hi was looking help on how to get my sky q box working on my projector and I came arias your comment, I'm just wondering if you could help me these are the specs of my projector is it compatible for the sky q box, it's a movie mate pro FHD if that helps
This message was authored by: RICKETTS
I have the same projector above and all i get is sound o dont get a picture
Typically the issue with a projector, particularly if it's on a ceiling mount, will be an overlong HDMI cable for the resolution.  Three metres is the maximum length over which UHD can be reliably transferred.
This message was authored by: Mattperry1
Hi all iv just bought a kjb projector i plugged my skyq box in iv got sound no picture what do i do
@Mattperry1
As above: check the specification of the device the length of the HDMI cable and the resolution of the Q box
Start with HD output and a maximum 3 metre HDMI cable to confirm the projector works at all.
