Discussion topic: Setting up a projector
Message posted on 19 Jun 2024 11:08 AM
Re: Setting up a projector
Yes, I will give that a shot, willing to try anything
Message posted on 19 Jun 2024 12:06 PM
Hi @Glenn21
Cannot find any confirmation that your Projector supports HDCP 2.2.
As this is normally required for 4K content most modern 4K TV sets will support this.
However your projector is not 4K capable and is 1080p resolution.
As 1080p doesn't need HDCP 2.2 support it's possible that your projector also does not support HDCP 2.2 which a Q Main box requires.
It's specification says it includes HDCP but does not clarify which version.
If it will not work with a shorter HDMI (3 or 4M) then I suppose you could consider using a Sky Q mini which could possibly be located nearer to the projector and could therfore use a shorter HDMI cable. Minis will not require HDCP 2.2 support.
Message posted on 19 Jun 2024 12:43 PM
I have a mini in the other room which I use for multi room, I could swop the boxes around and it may work.
Message posted on 19 Jun 2024 01:04 PM
Hi @Glenn21
You could certainly try your Multiroom mini with the projector.
However you cannot swap a mini position for the main Q box position because the main Q box needs the cable connection from the Satellite dish.
Message posted on 19 Jun 2024 01:08 PM
Yes thats a good point.......I will give all these options a go later.
Message posted on 19 Jun 2024 08:49 PM
So, I've got it work and I'm believing it's a HDMI issue, I plugged the projector into the sky box with the sky HDMI cable and it worked.....obviously my 8K Amazon HDMI cable isn't good enough or the wrong one, my next question is can anyone recommend an 8 meter HDMI cable? It will HD only not UHD.. ..Thank you everyone for your help.
Message posted on 20 Sep 2024 11:02 PM
@MightyQuinn hi was looking help on how to get my sky q box working on my projector and I came arias your comment, I'm just wondering if you could help me these are the specs of my projector is it compatible for the sky q box, it's a movie mate pro FHD if that helps
Message posted on 18 Oct 2024 10:36 PM
I have the same projector above and all i get is sound o dont get a picture
Message posted on 19 Oct 2024 12:57 PM
Typically the issue with a projector, particularly if it's on a ceiling mount, will be an overlong HDMI cable for the resolution. Three metres is the maximum length over which UHD can be reliably transferred.
Message posted on 18 Oct 2025 12:37 AM
Hi all iv just bought a kjb projector i plugged my skyq box in iv got sound no picture what do i do
Message posted on 18 Oct 2025 07:40 AM
As above: check the specification of the device the length of the HDMI cable and the resolution of the Q box
Start with HD output and a maximum 3 metre HDMI cable to confirm the projector works at all.
