Discussion topic: Mini box
This message was authored by: sweepsusiedog
Mini box
Hi all, having problems with skyq mini box. Put in 3 numbers on remote eg 145 but box takes ages to change channel. If I try to rewind recordings it will takes a horrendously long time or not rewind at all.
Any advice would be greatly appreciated, cheers
Re: Mini box
Try a power cycle on the main box.
If it continues then it may be an issue with the main box.
Avatar for sweepsusiedog
Re: Mini box
Whats a power cycle, switch it off then on again?
Re: Mini box
Yup.
Re: Mini box
Okay, thanks for your advice
